Taimosa_Eregie
Dec 30, 2024 1:55 PM UTC
Export local variables as a single file for handoff
Description:
The feature allows users to export local variables from Figma as a single file, making it easier to share design tokens and maintain consistency across projects.
Current Format:
Currently, local variables in Figma need to be copied individually or manually noted down, which can lead to errors and inconsistencies when transferring information between team members or projects.
Proposed Enhancement:
Implement an export option that allows users to select multiple local variables and save them as a single JSON or PDF file. This file can then be easily shared or imported into other projects or reviewed by developers.
Benefits:
  • Streamlines collaboration by ensuring all team members have access to the same variables.
  • Reduces manual errors and saves time in the design handoff process.
  • Enhances consistency across designs by providing a single source of truth for variables.
Others:
This feature could also include an option to import previously exported variable files, creating a seamless workflow for teams working on multiple projects.
IonuBalonu
Dec 21, 2025 6:58 PM UTC
Hey!
I might have the solution for you… check out PRISM Tokens: https://console.prismtokens.app/
It’s a SaaS tool designed to bridge the gap between Designers and Devs… and the best part… IT’S FREE!
How it works:
- Designer manage and update styles in Figma
- PRISM syncs the Figma file and transforms the data (aliasing, rem unit conversion, rgba conversion, sync diffing and WCAG accessibility report)
- Developers get fresh, production-ready code instantly (different CI/CD workflows baked-in, like GitHub Actions or Tailwind config).
P.S. There is also a Figma plugin: https://www.figma.com/community/plugin/1582392311915034049/prism-sync that you can use to sync Variables…
Give it a try and let me know what you also. I’m also opened to feedback and adding more improvements/features into the product.
Thanks!
