Duplicating projects
  • April 1, 2021
  • 43 replies
  • 13999 views
Jackson_Fox
Today: As an agency, we’re frequently starting new projects for new clients. We’ve evolved a set of best practices for Figma file organization, per-client design systems, etc. These best practices have been captured in a Starter Project project in Figma. However, to use this Starter Project each designer must duplicate each file in the Starter Project individually and then move them over into a new project.
Idea: We’d love to see Figma support duplicating projects in addition to the existing file duplication functionality. This would be a small but noticeable improvement in efficiency for spinning up new client projects.
Guillaume_Hambourger
You have a library in your Start Project?
  • April 13, 2021
You can select all files in the project (Cmd/Ctrl + A), right click, click duplicate and then move them to the new project via drag & drop.
Murillo_Teixeira
I have a template project (with Figma and Figjam files) and it isn’t easy to create a new project based on this template. I have to duplicate files, sort them and move to a new project.
If I could duplicate a project my workflow would be simplified.
My team also feels the same way about this
Julien.fischer
@Gleb Unfortunately, this is not going to solve the problem.
If you have files A and B (with components syn together) and duplicate these 2 files.
C and D components won’t be linked anymore…
Henricco_Marcieri
Hello Community!
We are a Design Agency based in Sydney with vast experience with design systems, variants, componentization, and file organization.
In this article, we illustrated why we believe the absence of an essential feature is slowing down the large-scale implementation of design best practices and costing a lot of money and working hours for design agencies and organizations.
Please, check out the article link in the comment section.
(It seems like we can’t include links in a post).
It will be fantastic to have feedback from the community on this.
I hope you are all well and safe!
Julien.fischer
Marek_Pietruszko
+1, sick of doing the same work every single time a new project starts, when you try to have a repeatable flow.
Gui_Ranieri
Some of us use projects as a templates do estandardize other projects across the company. Could we have a “duplicate” on a project level?
Hannah_Durbin
Reviving this topic - seems like it is still a missing issue? I am a recent Figma user and have been trying to figure out if I can duplicate projects from the project level instead of each file individually.
Jeroen6
  • September 21, 2023
I noticed this topic has been revived in Mar 2022, we are now 1 year+ later, but still I can’t seem to find a copy project option? Anyone?
Alx
I agree with your suggestion. Even as a product designer, I often start client projects with interdependent “Figma library project files”. Each time I start a new project, I find myself dedicating several hours to adjusting components or library styles applied to certain components.
Mojo
  • September 27, 2023
This needs to happen, I know is not a popular feature, but same issue here. We, as a team have a project template file and we are struggling with the loss of the styles connection with the components
Kristian_Bangso
Same here. We are a design/web agency and this is how we also work web-wise to cut time setting up basic things. Let us copy projects!
Please make this possible!
Same. We are huge telecom company and duplicating or exporting the whole project is very essential for us cause duplicating files leads to loosing links between each other
Jean-Marc_Lehwald
We really need this feature!
As we have components nested in others and different releases, the library swap does not work if the instances are nested, so the only way to do it would be to copy the whole team, which is not possible yet. Don´t know how to go on further, I´m working at DHL and this feature is so hard needed please make this happen soon!
Will_Hancock
+1.
We have the following use cases;
  1. Project Start - Duplicate a starter project containing UI Component Libs and files.
  2. Transferring work to a client’s Figma account. We can transfer Projects or Teams, but we would like to maintain or keep a version. So Ideally we duplicate, and then transfer 1 version to the client Org.
  3. Disaster recovery - Duplicate a whole setup for backup. Quite important for a large structure for an entire organisation’s DesignOps.
kishor_kumar_khadka
Just keeping this thread active. Please let us duplicate entire projects as the others have mentioned. Thanks
jponch
  • March 5, 2024
I just want to +1 this request! We’ve worked to establish project best practices that we can continue to refine over time, but the biggest limitation to doing this well is the lack of ability to duplicate a whole project, maintaining the various variable/component/style relationships within the files in said project. Been wanting this feature for years now.
  • March 6, 2024
Hey All, thanks for the feedback!
We’ll pass this onto our team to consider making duplicating projects easier in the future.
Thuan_Nguyen1
This need to happen ASAP Figma!
We really need this feature - glad to know others are raising the case. Would love to see someone at Figma chime in here and let us know.
Glad to see others on the same thought train here. This is a needed feature for a lot of agencies, any updates on if this is in the pipeline? - At the moment not knowing if this feature means taking additional consideration in the set up of projects if you want the ability to utilise the baseline set up for new projects further down the line.
Merlyn_Meredith
Duplicate Project is an essential missing feature. Manually doing this for complex design systems is particularly painful… 😢
Emile_S
  • May 17, 2024
I take it the plugin api doesn’t provide an avenue for writing your own solution? Either by fixing duplicated files components connection to a shared library, or some other approach?
  • May 23, 2024
Another user asking for the same feature… Please!
