MarcF
May 11, 2021 9:41 AM UTC
Compare versions in Version History
Hi,
I’m looking for a way to see what has changed, in the versioning, when viewing Figma files sent to me. As far as I can tell you can only view old versions and not see what changed between an old version and a current one. It’s particularly difficult to detect changes on files with many pages/boards/wireframes.
It would be great if you could click a version and compare it to the current version with a highlight and greyscale/colour content to easily see what’s new/what’s not.
Thanks
QuietNoise
Jul 27, 2021 12:40 AM UTC
Would love to have such feature. Especially usefull for developers who get bombared with multiple versions of same design when only a tiny, hard to find details are changed like font size, shade of color etc.
My workaround for now is take screenshot of the last version I worked on and a screenshot of the latest file. Then I paste both of them to Photoshop and set up top layer blending mode to Difference. This will make all changes nicely highlighted.
I’m pretty sure similar feature could be easily implemented in Figma itself. Maybe even a plugin could do that?
David_Turgeon
Feb 17, 2022 4:30 PM UTC
If a designer makes a text tweak in an autosave version there should be a way to have a pointer (or something) that zooms you in or highlights the area of interest. The difference (layer blend mode) workaround is an intriguing idea yet on large workspaces a comma (a small tweak) could be hard to see.
Jason_Mak
Feb 18, 2022 3:23 PM UTC
Just adding to this. Miro has a nice feature that shows you what has changed since you last visited a board. I think this kind of visual pattern, just highlighting elements and saying when they changed (and by whom) would be a great way to visualise this.
Context: we are seeing our engineers not notice small changes when they’re made and are looking to spot when changes have happened so we include these.
Will_Neville
Jun 8, 2022 7:46 PM UTC
This is an AWESOME IDEA and would compliment if not give History an even better meaning. Now, I only use history to look at really old changes that are obvious. I also use it to revert design system changes. I also look at it to see if other designers changed my file but again, cannot see what they changed unless it’s obvious.
Today, I literally have to have a change log list inside my file telling devs, PM’s, BA’s what changed. This sucks because I am only selective about the changes like changed color black to blue on “frame name.” I do not mention things like spacing or minor movement because there would be hundreds of lines since we tweak as designers. I also have three default pages in all of my files. A dated current version and a dated old version and archived. This is to help with some distinction. Even still I doubt devs can tell the difference. Adding this would eliminate all of the above.
Aen
Sep 15, 2022 9:21 AM UTC
I need this. I saw one of my designers made modifications in history and he claims he just opened the file and copied some stuff. But the version history shows multiple edits in several components. I need to be able to know exactly what changed. Otherwise it’s like seeing a pull request and not seeing what’s changed.
YoungHyuk_Kim
Oct 17, 2022 9:53 AM UTC
Totally cool. I need this too.
John_Hutchinson
Nov 17, 2022 12:08 AM UTC
Definitely need this. Labview has a very thorough method to describe differences. It allows you to select how “sensitive” the diff is. For example, do you just want to see what is added, or see every move, resize, text change etc
Blazej_SLEBODA
Nov 24, 2022 1:43 PM UTC
This would be great to have this feature.
Rafael_Gomes1
Dec 1, 2022 12:49 PM UTC
This would be very helpful. Does anyone know if there’s a plugin that already does this? I was looking into Visual Difference, but it doesn’t seem to allow comparing it based on the version history.
Jarek_Marciniak
Dec 6, 2022 4:27 PM UTC
Yes please +1
