Kevin_Plunkett
Dec 8, 2022 4:28 PM UTC
Add Connector Lines to Design files
Currently, if you copy + paste a figjam flow into a Design file, the Connector Lines stay fully functional – they stretch and adapt as you move their origins and destinations around the canvas, and you can move their origins and destinations to your frames, components, etc.
I’ve been using this to show user flows within my UI designs, not only for ease of sharing with other teammates (no need to give in-depth walkthroughs), but also for easily identifying missing states within a flow.
It would be great if a) the Connector Line was added as a tool to Figma Design, or b) basic lines and pen vectors had the option to act as connector lines – attaching to anchor points on objects and components, scaling when the endpoints were moved, and able to be adjusted with mid-line handles.
Mar 8, 2023 4:29 PM UTC
Jul 12, 2023 9:03 PM UTC
Currently, if you copy + paste a Connector from a FigJam into a Design file, the Connector Lines stay fully functional – they stretch and adapt as you move their origins and destinations around the canvas, and you can move their origins and destinations to your frames, components, etc.
I just want to have a tool for drawing them without having to copy and paste them all over the design file when wanting to use a connector for showing flows and direction and being able to shift componenets without having to then adjust the arrows as well.
Rasmus_Rosander
Mar 19, 2024 11:09 AM UTC
I love this idea. But I don’t think Figma will do it because they want us to use FigJam for that feature…
Marina_Litvin
Apr 26, 2024 1:13 PM UTC
I also use the Connector line feature in Figma to show flows and find it very easy to use. However, I would like to enhance this feature with the following capabilities:
  1. Allow it to connect to specific instances inside a component (not just the master).
  2. Enable duplication of the Connector line without preserving the connection between frames. Simply copy a single Connector line.
Kenneth_Marcantonio
Apr 26, 2024 4:03 PM UTC
+1 for this 👍
Jul 10, 2024 6:02 AM UTC
This would most definitely be a great addition to our workflow. +10000
Aug 7, 2024 11:20 AM UTC
If you press cmd while dragging the connector it will stick to any position of the instance, so you can add the connector next to any element and if you drag the instance the connector stays sticky to where you positioned it. It’s a nice workaround.
Marina_Litvin
Aug 7, 2024 12:28 PM UTC
Oh. WOW!
It does work! Thanks a lot for that trick. c:
Zark_Aoui
Sep 2, 2024 11:05 AM UTC
Is this still working! It doesn’t work for me!
Mantas2
May 26, 2025 11:39 AM UTC
I’d add: Allow connector lines in Components, right now you just can’t add them inside of component
