Ability to "un-Component" something
  • March 21, 2024
  • 1170 views
Basically, I want to be able to take something that I’d previously made into a component and “uncomponentise” it. Currently, I have to either delete it (not good for version control) or make an instance, detach the instance and then delete component.
I just want to be able to turn the component off so that it’s no longer in libraries etc.
Hey! Thanks for your feedback. We will pass along to our team for consideration.
In the meantime, I’ve found a workaround shared by the community that may help you (by using a plug in):
Power Member
March 22, 2024
You don’t need to use a plugin, simply create an instance of the component, detach it, then delete the component.
Alex_Hazel
Agreed! There should be a keyboard shortcut to "revert main component" that eliminates the need for three additional steps and a cumbersome workflow that doesn't align with anyone's mental model or how most other features in Figma operate. If I can detach an instance, I should also be able to "detach a main component" or "revert to layers," or something similar.
