Ze_Tan
Feb 14, 2024 8:59 PM UTC
Variables shows a mixed default mode in components
I created two modes (Light and Dark) with semantic tokens in my library and applied them to all the components. According to the Figma documentation, the most left column of the Variables settings page is the default mode. https://help.figma.com/hc/en-us/articles/15343816063383-Modes-for-variables#h_01HMD3VBSV4SD76PH8BVZY8Z13
But in my library some components show light mode by default and some components show dark mode by default. How to solve the problem and make the all default mode as light?
Ze_Tan
Ze_TanSolution
Feb 15, 2024 4:11 PM UTC
Thank for providing the solutions, but I checked all nested components and everything looks good.
I finally found the reason!!
Figma provides two ways to change the mode of variables. One is to apply different modes across the entire page and the other is to apply them on individual layers. I changed the page mode to “Dark” so all layers on the page have Dark mode overridden as the default mode. What I need to do is to make sure the Page and Layers are all set to light mode.
Raphael_M
Power Member
Feb 15, 2024 3:52 AM UTC
Hi, Ze_Tan.
Have you checked the layers if it is set to auto by default?
Shrivathsan_G_R
Feb 15, 2024 5:07 AM UTC
Here are two viewpoints to consider:
  1. Possibilities that there could be a manual override of the theme selection on components accidentally from light mode to dark mode
  2. Another perspective suggests that there might be two design system variables at play: one could be a published token applied from an external source, while the other might be using locally declared variables within the same file.
Ze_Tan
Ze_TanAuthorSolution
Amanda2
May 31, 2024 8:55 PM UTC
you helped solve my issue, thx!
