Youssef3
Oct 2, 2024 10:28 AM UTC
Variables order not always the same as the figma UI
0: {name: 'color/Brand/Alpha/Primary', id: 'VariableID:1:18'}
1: {name: 'color/Brand/Alpha/Secondary', id: 'VariableID:1:3'}
2: {name: 'color/Brand/Primary', id: 'VariableID:1:17'}
3: {name: 'color/Brand/Secondary', id: 'VariableID:1:5'}
4: {name: 'font/family/primary', id: 'VariableID:1:8'}
5: {name: 'font/weight/regular', id: 'VariableID:1:10'}
6: {name: 'font/weight/medium', id: 'VariableID:1:11'}
7: {name: 'mode/modes', id: 'VariableID:1:7'}  <- resolvedType: String
8: {name: 'font/family/secondary', id: 'VariableID:1:9'}
9: {name: 'font/line height/string', id: 'VariableID:3:2'}
Hey everyone,
This is what’s returned by getLocalVariableCollectionsAsync().variables, and as you can see, the order isn’t correct. For instance, variables inside the font folder should be grouped together, and color/Brand/Primary & Secondary should appear before the nested folder color/Brand/Alpha.
It seems that whenever a string is involved in a variable collection (like in mode/modes, which is of type String), it messes up the order. I’ve noticed that if I randomly move the variable and then put it back in the correct place, sometimes the order is fixed, but other times it’s still completely off.
Has anyone else run into this, or found a reliable fix?
Sasch
Oct 8, 2024 8:59 AM UTC
Good catch. I got the same issue/question. Is it not possible to fetch the collections and their variables with their original structure and order? @Gleb please do your magic and help us 😁
Designing systems that empower gripping experiences at scale.
Power Member
Oct 8, 2024 9:11 AM UTC
Not possible unfortunately. Hope they fix it someday.
Sajid
Jan 24, 2025 6:48 AM UTC
@Youssef3 Have you found any solution to this?
Omar_Alharbi1
Feb 13, 2025 9:13 AM UTC
This. All plugins are now reporting variables order different from UI and what designers are seeing. Forcing them to reorder any output of theses plugins.
