Running into "File out of memory" while resolving conflicts
Show first post
Tyler_Nixon
Is Figma support watching this thread @raquino, and are there any suggestions? We recently upgraded to the organization plan and have run into this issue, and it’s a problem. The files are not even that big. It’s the process of merging that causes a memory spike and, ultimately, this error. Can someone please advise.
Emi_Rodriguez
+1 to this - Cleaned up the file and reduces the size and nothing…
A few days ago it was saying that there was an update from the main to the branch and was for “optimization” only, no real changes… that’s when it crashed for the first time and then this started happening where I can’t resolve conflicts nor merge the branch
Matt_Rea1
  • 15 replies
  • March 8, 2023
This is exactly what happened to me - stuck in branch limbo unable to merge. I think main and feature branch were both smaller than 1GB. I can’t recall exactly how I resolved this (after backing up both files, and reverting back to earlier versions, I think I was able to get changes back into main with some manual updates)
After that ordeal (which came at end of sprint) I ended up breaking up my main file into separate files, and no longer use branching. It was a pain because we had to re-link lots of tickets from the old monolithic file to the new files, devs and other stakeholders needed to remap bookmarks, and had to keep the old file around with instructions on where to find the latest up to date designs. It was not a great look for me, our design team, or Figma as a tool.
Eliza_Jensen
I’m running into this several times too…any solutions yet? I haven’t found a pattern for when it happens and when it doesn’t.
dvaliao
  • 4707 replies
  • April 3, 2023
Hey All,
Solutions will be case by case, depending on your file. The forum is primarily managed by the community, so please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use provide a link to your file and share it with support-share@figma.com.
Olivier_Bubendorff
Hi all,
I found a method to get out of this rut that worked in my case (0.55GB file, cannot merge Branch because of too much modifications from the Main File):
  1. Be sure that all the Main File is correctly up to date with your latest needs
  2. Create a new branch
  3. Paste in this new Branch all edits from previous Branch
  4. With a smaller gap with Main File, the new Branch is ready to merge
  5. The first problematic Branch can now be archived or removed
This solution doesn’t need to lose Branch’s work or step backwards in the main file.
Hope this helps!
cstn.l
  • June 22, 2023
I can also confirm that this is a concerning issue for our enterprise Figma usage.
Besides that the previews in the conflict panel load painfully long, this memory error is a real blocker to us currently.
I was also disappointed to not hear about any improvements to branching on config.
Emil_Sjoberg
Experiencing this as well in our team. Terrifying when you have so many files depending on these libraries that won’t merge.
  • July 13, 2023
Also experiencing this and it’s super problematic. Makes Branching practically useless if we can’t reliably Branch without the risk of being locked out of Merging.
Smaller changes might be a solution but this invalidates the freedom of branching as well, giving it an artificial limitation that makes it far too much of a hassle to bother with.
MartinFujak
Same here, branching is useless! Moved all unnecesary pages, told all the devs to look into seprate file, and still getting the error 😦 needed to manually copy from branch to main file and fix all the issues.
Martin_Lewandowski
Same issue here. Feels almost pointless to have branches when you are not able to actually use them in the process…
Jullian_Claus
We also ran into this problem today. After a lot of trial and error I was able to merge the branch while taking the following steps…
  1. Open the file in your browser. I used Chrome and made sure all other tabs were closed and that in the browser settings the memory and power saving modes were disabled.
  2. Before merging I first updated the branch from the main file
  3. In the resolve conflicts screen it took a long time to load. Be patient… when the screen was fully loaded I resolved the conflicts all in one go, instead of resolving every individual conflict one at a time. I feel this did the trick in our situation as the memory usage warning didn’t reach 100% this time.
  4. Merged the branch into the main file with no remarkable problems, it was a bit slow though. After merging the branch the memory issue vanished.
Hope this helps ✌️
Jorge_Montero_GFT
Hello!
I think we all have the same problem, and the problem gets bigger when you have all the links already generated on other platforms.
When you merge, you have to wait decades in front of the computer, or just close the app.
In my case, with a document that only takes 157,9mb, linked to 6 component libraries, it is impossible for me to work with branches.
I wasted hours waiting, and after waiting, watching the screen go blank (in Figma grey), with nothing saved.
I’m going to write a report, but having to explain to a client that I’m going to let a third party see a confidential project, I don’t think he’s going to be amused, and he might not even let me do it. In this case, what should I do?
Duplicate an entire project by removing any reference to the client or the system used?
I have to justify those hours in terms of budgets.
How do I justify that with the amount of money we pay per year to Figma, I have to solve a problem generated by Figma?
Thank you for your patience @dvaliao
Alex_Lima
  • September 18, 2023
I’ve been having this problem for months, I’ve lost a few branches and merging them has been a nightmare. When I click on “update form main” Figma crashes right away.
I even divided my main file into two others to become smaller, but somehow it is worse now.
David_V
  • September 19, 2023
Yep, happens all the time, with every preview the memory usage creeps up by 1 or %2.
I managed to get the file up to 99% memory usage this morning, it literally feels like a ticking timebomb. No idea what happens after that but I didn’t wait to find out and had to restart. Not good Figma, especially when you are on a client call! 😤
Shaun_McHugh1
This is a real problem. I think it stems from the fact that even on the desktop Figma runs in a browser. There seems to be approx 2gb RAM limit which is not enough for large design system files (which is where you really need branching).
Nightmare… please resolve
Same problem, since turning on Enterprise with branching enabled it has never succeeded in successfully updating from the master branch to the other branch, it has always been out of memory, even with only ten conflicts. I think such a feature is unusable, and it is a huge loss of confidence for enterprise users.
Kristaps_Stikuts
I got a file with 17% percent memory usage, but when reviewing updates it skyrockets to above 80%.
The only thing I’ve been able to do is delete content of a branch and then copy from main file, but this may break components, so need to use external plugins to connect them, which might result in undesired consequences.
Please, Figma, fix.
Achille_Perrin
Same problem here.
I’m pretty concerned about the fact that this problem seems to happen regularly and there are no clear solutions or guidelines as to what can be done to avoid the issue. The initial comment was published in July 2021, I’m writing this in Feb 2024, and people seem to still be having issues with this…
Olivier_Boulais
Same problem file is too heavy to merge and can’t resolve conflicts because we’re running out of memory is there a temporary alt we can do while Figma team takes care of fixing this issue once it for all?
