Insert image shortcut
Phe
I am having trouble with a keyboard shortcut, have any of them been changed?
Ctrl +shift + K was opening up the window to insert media like images but no longer does so.
Instead it opens a window to search or ask a question, anyone familiar with this issue, up until this point haven’t had an issue with any of the shortcuts.
Best answer by Sarobidy_RAMIANDRISOA
Hello ​@djv
I found out that [Ctrl+Shift+K] is the shortcut for the Notion app to open the quick search screen.
I uninstalled Notion then tried the above shortcut to import images in Figma and it works like nothing ever happened 😅
I’ll reinstall the Notion app but I’ll have to change the shortcut either for Notion or Figma if its possible.
Hoping that could helps!
  • 4943 replies
  • July 16, 2025
Hi ​@Phe, thanks for reaching out!
What OS are you using? And are you using Figma in the browser or the desktop app?
If you’re using Windows, Ctrl + Shift + K should still be working as expected.
If you’re using macOS, can you please try using Cmd + Shift + K?
This shortcut is still working on my end (both desktop app and browser), and I’m not aware of any recent changes.
With more info, we can work together to find a solution.
Hi. I have a similar problem. When I use the shortcut Ctrl+Shift+K, nothing happen, either in browser or desktop.
What could be the problem ?
Drag and drop picture still works though
  • 4943 replies
  • July 21, 2025
Hi ​@Sarobidy_RAMIANDRISOA, thanks for following up about this!
I assume you are also using a Windows device? Are you also using the most up to date version of Figma? And if so, when was the last time you recall it working as expected?
If this is specific to Windows, we can have our team start there with our investigation.
Hi ​@djv . Yes I use a Windows device. And yes, I use the most up to date version. Last time it worked without any problem was 17-07-2025.
Thanks for your support
Phe
  • July 30, 2025
Hi ​@djv, thanks for getting back to me!
I’m using the app on windows, on the most recent update.
I’m not sure of the date of the last time it worked but it has definitely been a couple of weeks now.
Other shortcuts are working fine.
Hello ​@djv
