Hover state doesn't reset
Show first post
Vasundhara_Ghose
Thank you its worked 🙂
Matt_Birtch
Still having this issue
Mark_White1
  • June 14, 2024
How is this still a thing! Come on Figma, this is basic interactions and its driving me mad!
I’ve tried using the ‘reset component state’ and options others have mentioned here.
This wouldnt be such a problem if I could also apply ‘change to’ to ‘this’ component within the component I’m in.
Please, Please, please fix this its 3 years old!
Bez1
  • 9 replies
  • July 18, 2024
Also facing this issue. mind boggling this hasn’t been fixed more than 3 years later
but more frustrating is the fact there is not a single dev response here acknowledging this issue. I guess since Adobe didn’t buy you at the end, you decided to just be like Adobe>
Very disappointing
Esther4
  • August 19, 2024
Same issue here.
When using the “mouse leave” workaround, all is well until I navigate to another page where the component is present. The component in question resets to the hover state upon navigation. I have to hover over it once more to reset it to normal. I wasted hours trying to fix this.
Super infuriating, especially when running usability tests 😕
jbrycedavis
  • 10 replies
  • September 17, 2024
Bumping - same things here…
Joe_Cloughley
  • 5 replies
I have this issue as well.
Jermold_Compton1
Bump. I’ve been facing this problem as well.
Sebastien_Boval
Same here. Quite annoying.
Thompson
  • 9 replies
  • October 13, 2024
I’m not certain this is the same for everyone else, but, for me, it is always when I have a component with a hover state interaction nested in another component. Refreshing the prototype window doesn’t fix it. Work around? Use ‘on mouse enter/exit’ instead of ‘while hovering’. 🫤
Darrell_White
  • 10 replies
  • November 12, 2024
We have the same issue, but it’s on ‘while pressing’ and opening an overlay.
FIGMA prototype: https://www.figma.com/proto/OOInghc3e8eBi3iAOD3zFE/Notices?page-id=47%3A1801&node-id=2458-15232&node-type=frame&viewport=-5030%2C2883%2C0.34&t=S47GhztUGHQYiLk9-1&scaling=min-zoom&content-scaling=fixed&starting-point-node-id=833%3A16668
  • Click on the ‘Add or edit’ text link
  • Cancel out of overlay
  • Button still retains state for mouse down/press
Hari1
  • December 4, 2024
I see multiple posts regarding this issue. The earliest one was back in year 2021. And now it is almost end of 2024. 3 years down the line and Figma cannot fix this issue? Not sure why the CONFIG & other marketing events are happening to promote Figma, but the team really need to look at the forums and make sure these type of critical issues are solved first.
Hampus Svallfors
Make sure your components’ pressed or hover state have a “Mouse leave” interaction, pointing back to the default ‘resting’ state. This will make the component “reset” to the resting state when opening an overlay. This works at least 90% of the time for me.
