Figma components do not update from one file to another
  • September 18, 2024
  • 5 replies
  • 258 views
Cristian_Banu
Hi guys,
Is this a bug or is it a missing feature? If I take a components from one file, and I use it in another file, and after using it it the second file I make some changes in the original component, the changes won’t reflect in the second file. I basically need to copy it again from the main file to the second file.
Krishnamoorthy
Even I’m facing the same problem. Any solution will be much appreciated.
Nellya
  • 664 replies
  • February 12, 2025
Did you publish file with a components as a library? Here is a guide to libraries
Krishnamoorthy
Hi Nellya,
I haven’t published them as a library since they weren’t strong candidates for that.
Just to clarify—components created in a different file won’t impact their instances in other files unless they are published as a library, correct?
Looking forward to your thoughts.
Best,
Krish
Nellya
  • 664 replies
  • February 12, 2025
Correct. This option is available on all paid plans.
adilhassan
  • 12 replies
  • February 12, 2025
It sounds like you're copying the component instead of linking it as a library asset. To keep it synced across files, try publishing the original file as a library (Assets panel > Team Library) and then use the component from there. That way, any updates you make will reflect automatically in all files using it.
