Cristian_Banu
Sep 18, 2024 6:38 AM UTC
Figma components do not update from one file to another
Hi guys,
Is this a bug or is it a missing feature? If I take a components from one file, and I use it in another file, and after using it it the second file I make some changes in the original component, the changes won’t reflect in the second file. I basically need to copy it again from the main file to the second file.
Krishnamoorthy
Feb 12, 2025 8:24 AM UTC
Even I’m facing the same problem. Any solution will be much appreciated.
Nellya
Power Member
Feb 12, 2025 9:08 AM UTC
Did you publish file with a components as a library? Here is a guide to libraries
Krishnamoorthy
Feb 12, 2025 10:47 AM UTC
Hi Nellya,
I haven’t published them as a library since they weren’t strong candidates for that.
Just to clarify—components created in a different file won’t impact their instances in other files unless they are published as a library, correct?
Looking forward to your thoughts.
Best,
Krish
Nellya
Power Member
Feb 12, 2025 10:49 AM UTC
Correct. This option is available on all paid plans.
adilhassan
Feb 12, 2025 11:03 AM UTC
It sounds like you're copying the component instead of linking it as a library asset. To keep it synced across files, try publishing the original file as a library (Assets panel > Team Library) and then use the component from there. That way, any updates you make will reflect automatically in all files using it.
