noodle312
Jun 13, 2024 12:45 PM UTC
Figma App: Header Area not reacting properly on iPhone
Hi there!
I’ve encountered an issue when running my mobile prototypes on an iPhone with the Figma App.
Actions placed in the header area (around 44px from the top) will not react on click/tap events. I have run some tests (see the screenshot)
The green squares react on the on click event and open the overlay. The red ones don’t.
The third square reacts from the bottom half of it.
Also tested it with bigger squares to make sure that the clickable area isn’t to small, but had the same result.
The issue occured on: iPhone 13 Mini, iPhone 13 Pro Max, iPhone 15 Plus.
However it worked on an iPhone SE (with the black bars on top and bottom).
It also works as expected on a Samsung Galaxy A40.
Thank you in advance!
Michael
noodle312
noodle312Author
Jun 13, 2024 12:46 PM UTC
Additional info: Frame Size is 375x812px
Dejan_Djuric
Jun 13, 2024 12:48 PM UTC
Same problem here.
I reported this inside the Figma app…
Yesterday I was using the Figma app and the prototype was working just fine, but not today!
Jun 13, 2024 9:11 PM UTC
Also experiencing same issue and have a deadline to prep prototype. Figma, please help!
Greg_Arroyo
Jun 14, 2024 12:22 AM UTC
I’m having the same problem. I also noticed that when this started I can now also see the iOS system status bar on top of my prototype. Neither of these issues were happening yesterday or for the past month that I have working on this prototype.
Dejan_Djuric
Jun 14, 2024 4:10 AM UTC
I forgot to mention that. Yes, the status bar is now visible, and because I already have a status bar in my design, now it’s double and overlapping.
This and the previously mentioned problem with hotspots is the case only when you open the prototype but not when using a mirror mode.
noodle312
noodle312Author
Jun 14, 2024 8:06 AM UTC
Okay guys, I found out something interesting:
The bug is related to this bug I created this morning: [Figma App: iOS Status Bar hides after two-finger long press]
The header area is working properly WHEN the status bar is hidden!
How to recreate:
  1. Start prototype
  2. Two-Finger long press (iOS Status bar disappears)
  3. Actions in the header area are triggered ✅
After second two-finger long press the status bar appears again and the actions aren’t triggered anymore.
Dejan_Djuric
Jun 14, 2024 8:28 AM UTC
I opened my prototype, a two-finger long press, and I got the prototype menu, but the status bar is still visible and I can’t click in the upper section of the header.
So, not working for me.
noodle312
noodle312Author
Jun 14, 2024 8:34 AM UTC
Which version of the Figma App are you using?
The had a release 15 hours ago (24.12.0) I had to trigger the update manually from the app store… hopefully this helps you 🤞
Dejan_Djuric
Jun 14, 2024 8:58 AM UTC
Nice, I have updated the app manually and it’s working like you said. Thanks!
It’s better than it was, but the problem is still there. Hopefully, they will sort this out in the next update.
Greg_Arroyo
Jun 14, 2024 1:18 PM UTC
I actually think Version 24.12.0 is what caused this bug. The timing of this release is when the bug started. Their previous release was a week ago and everything worked fine up until their release yesterday.
