Lucas_Miqueias
May 2, 2023 7:56 PM UTC
Error when changing value of imported variant?
I’m getting this error when changing the status of a variant from true to false with the setProperties function
`Uncaught Error: “Unexpected: _dirty” in ~SymbolOverrider (FGSymbolOverrider.cpp)
Uncaught Error: “Unexpected: scene()->mutationsAreDisallowed()” in set (FGNode.cpp)
Uncaught Error: “It shouldn’t even be possible for a read-only scene graph observer to recurse.” in handleObserverEvent (FGSceneGraphEvent.h)
My code is like this
[image]
jak_e
May 3, 2023 5:18 PM UTC
can you provide the code where component is defined?
Lucas_Miqueias
May 3, 2023 9:37 PM UTC
Hey Jack, the main code is right below. But the error is not in the component. This error only happens when I change the Header variant in the Box
import { on, showUI, once } from '@create-figma-plugin/utilities'
import { ResizeWindowHandler } from './types'
export default function () {
  on<ResizeWindowHandler>(
    'RESIZE_WINDOW',
    function (windowSize: { width: number; height: number }) {
      const { width, height } = windowSize
      figma.ui.resize(width, height)
  function handleSubmit ( valueInput: any, stateComponent: any, valueButton: any) {
    interface Button {
      value: string | boolean,
      count: number
    interface Trackers {
      value: string,
      type: string
    const trackers: Trackers[] = [];
    const buttons: Button[] = [];
    valueButton.forEach((i: { value: string, count: number; }) =>{
      if (valueButton.length === 0 && valueButton[0].value.length === 0) {
        const newButton: Button = {
          value: false,
          count: 0
      } else {
          value: `${i.value}`,
          count: i.count
        buttons.push(newButton)
    interface Body {
      header: string;
      body: string;
      footer: string;
    interface Component {
      plataforma: string;
      tipo: string;
      corpo: Body;
      botoes: any[];
    const component:Component = {
      plataforma: stateComponent.plataforma,
      tipo: stateComponent.tipo,
      corpo: {
        header: valueInput.header,
        body: valueInput.content,
        footer: valueInput.footer
      botoes: buttons
    (async () => {
      let importComponent = await figma.importComponentByKeyAsync('***')
      let instance = importComponent.createInstance()
      let page = figma.root.children[0];
      page.appendChild(instance);
      const nodes = figma.currentPage.findAllWithCriteria({
        types: ['INSTANCE']
      const elementNames: string[] = [
        'Component', 'Header', 'Content', 'Input', 'Rodapé', 'Botões Quickreply'
      const elements: Record<string, any> = {};
      for (const node of nodes) {
        const index = elementNames.indexOf(node.name);
        if (index !== -1) {
          elements[elementNames[index]] = node;
      const {
        'Component': Component,
        'Header': Header,
        'Content': Box,
        'Input': Content,
        'Rodapé': Footer,
        'Botões Quickreply': BtnQuickReply
      } = elements;
      // INSERT DATA INPUT ON COMPONENT
      Content.setProperties({ 'Text#211:1': component.corpo.body })
      Footer.setProperties({ 'Text#520:0': component.corpo.footer })
      Box.setProperties({ Header : 'true' })
  on('SUBMIT', handleSubmit)
  showUI({
    width: 440,
    height: 740
jak_e
May 3, 2023 9:57 PM UTC
I believe the property name "Header" should be something like "Header#00:0" similar to the Text property names above it. You should be able to find that name in importComponent.componentPropertyDefinitions.
Also, can you confirm, is the Header property a boolean or a string for the component? The only other possible thing I see wrong on that line is if you should be saying:
Box.setProperties({ "Header#0:0": false });
instead of
Box.setProperties({ "Header#0:0": 'false' });
Lucas_Miqueias
May 4, 2023 2:55 AM UTC
Box is an instance of the component. This instance actually has the Header property and the value is a string.
figma2
The expected action happens, but I keep getting an error that looks like figma rendering itself.
jak_e
May 4, 2023 3:51 PM UTC
Oh I see, this is a variant. That naming makes sense then. When you say “the expected action happens” are you saying that the code works but there’s also an error?
Lucas_Miqueias
May 4, 2023 4:04 PM UTC
Exactly, the code works, the component is created and the variant value changed, but the error appears in the console.
jak_e
May 8, 2023 3:16 PM UTC
i dont think this is your fault. other people are reporting it happening in other scenarios we’re looking into it. thanks for bringing this up!
