Stoj_Filip_TR_Product
Nov 20, 2024 6:23 PM UTC
Copying and pasting any component gives a text box stripped of everything but the text of that component
I found similar posts, but they were resolved without any needed fixes. Here’s what I’ve tried:
  • Disabled Chrome extensions
  • Cleared Chrome cache
  • Did hard reboot of Figma tabs and MacBook Pro
This is a new issue as of 2 days ago and has not resolved.
Any component I copy>paste within the same file just copies the text and nothing else.
Note: I will add that this only occurs in one file. And when I paste something in or out from another file, it appears to work.
Sebastien_Danguy
Nov 21, 2024 10:46 AM UTC
Hi, I have another bug with copy/paste.
i assigned a string variable to a property of my component but if I copy/paste this component, I can’t see anymore the text of that property.
Example before/after:
NOTE: No problem when duplicate the component, only when I use copy/paste.
jmvanieperen
Nov 25, 2024 2:17 AM UTC
I run into the exact same issue as @Sebastien_Danguy. I’ve attached string variables to a lot of components (also components from our design system - in a different file) and when I copy and paste a component, the text box would be blank and I can’t see or reattach a string variable in the right side panel. Weird and really frustrating… and making the string variables unusable for my use case: being able to switch between different languages in my designs.
Marlena
Nov 26, 2024 7:37 AM UTC
Have you found a solution to this issue? It’s been bugging me for 2 days now.
Dec 2, 2024 3:00 PM UTC
I have not. I just started a new file and moved on from that file. I assume it was corrupt or some corrupt component that I copied from another file, so I just cleaned house on that file.
