Component state of my dropdown instance keeps changing to the main component in prototyping preview mode
Linh_Bui
I have a dropdown instance. In its open state I changed the text. But when I tried the prototype preview mode the text and the component keeps changing to the default text from the main component. Can you guys help me?
Go to file
Best answer by Pavel_Kiselev
Your component does not have any menu when it’s in “Idle” state so there is no way to keep your overrides to menu items in that dropdown. When you work with it in design mode Figma keeps a snapshot of your changes in the memory so it tricks you into believing there is magic behind it. You can easily check it yourself. Add a dropdown instance, change the state to “Open”, customize menu items, and change the state to “Idle”. Now reload the file and check your dropdown once again, you will not see any of your changes there. Prototype works the same way.
To fix your issue make sure that the dropdown is present in the “Idle” state, just keep it hidden
Pavel_Kiselev
Linh_Bui
  • June 13, 2024
Thank you so much! That’s so helpful 🥰
