iammai
Jun 22, 2023 2:21 PM UTC
'Change to' with conditional action not working
When based on a conditional I want the component variant to change to another one (depending on the conditional), it doesn’t let me choose it to go to two different change-tos. If I change one of them, it changes the other one immediately.
I would upload image or video but I can’t as I am a new user. But basically to replicate this:
  1. Create 3 variants of a component (eg a number 1, 2, and 3 in a frame, and make them into component variants, let’s say the prop is either 1, 2, or 3)
  2. Create a variable (eg. next that is 3)
  3. From variant 2, create an on click interaction that has a conditional:
if (next == 3){
change to props = 3
else{
change to props = 1
What you will see is that when you create the second change to, it is automatically set to props = 3, and if you try to update the second one to props = 1, it will change the first one to props =1 as well.
iammai
iammaiAuthor
Jul 18, 2023 8:18 PM UTC
Thank you!
WillBarrow
Jul 20, 2023 12:26 AM UTC
Definitely a bug. There are other related posts
MMM
Jul 20, 2023 10:11 AM UTC
I’ll attach a screenshot for clarity.
WillBarrow
Jul 20, 2023 8:27 PM UTC
I’ve since discovered that the reason I couldn’t select a variant in my “Change To” dropdown was because I had placed the click action on an already interactive button component (even though there was no existing click action, but that’s another matter). Once I wrapped my button component in another frame and applied the action to that, I was able to set the Change To option. Like everyone else here, however, I’ve been unable to add an Else Change To action or even a second Conditional with a Change To action without it changing and breaking the first Change To action.
WillBarrow
Jul 21, 2023 3:13 PM UTC
A workaround that I’m using until these conditionals get fixed is to create a separate, hardwired button for each of my “conditions” and tie each button to a boolean variable. Then I just need to set true/false for each button-variable on the navigation action that would otherwise set my conditions. I hope that makes sense and helps someone out.
Allison_Woo
Jul 27, 2023 11:28 PM UTC
@WillBarrow LIFESAVER - i was struggling with how to use a an interactive variant (a checkbox) to control a string variable with the conditional interaction and it just wasn’t working. ended up having to tie two buttons with different texts (that i was trying to use the string variable for) to boolean variables and then use conditional interaction to tie it to the checkbox 😭
Jul 28, 2023 9:09 AM UTC
I am having the same issues.
I cannot change the state here in the conditional interaction.
Angel_Claudio
Aug 14, 2023 3:47 PM UTC
Having the same issue:
Jake_Moore1
Aug 14, 2023 5:25 PM UTC
Yep, can corroborate that this is still broken. Submitted a thread a few days ago: Can't use conditional interaction inside interactive component
Hampus_Svallfors
Aug 15, 2023 3:39 AM UTC
Same here.
Aug-14-2023 19-29-06
