Vincent_Huss
May 6, 2024 9:47 AM UTC
Bug with gradient fills
Hi,
I have seen something that seems to be a bug in the plugin api,
(or if it’s not, i’d like to know what i’m doing wrong)
with a rectangle node container having a gradient fill, such as this
when accessing the getter fills in my code, i get an error message :
Uncaught Error Error: in get_fills: Cannot read properties of undefined (reading 'colorVar') at get_fills (<eval>/VM46947625:23:21)
and the call stack points to where i’m calling figmaNode.fills
I have searched my code for the pattern colorVar to check if I was doing anything funny with that, but it is nowhere there, it seems that the get_fills is the internal getter that gets called when calling .fills
I have a bunch of other rectangle with gradients that all work fine,
(only the one on the left is failing)
i have looked in details to try to isolate what’s unique about the left one, but nothing stands out, the rectangle contains 1 fill only of type gradient, here’s the config of the gradient
i didn’t use any color variable as the error message made me believe at first, nor do I have any variable with a similar name in my whole file,
Here is a screenshot of the fill list
Let me know if there is more detail i can provide that would help to reproduce.
Thanks
tank666
May 6, 2024 3:55 PM UTC
Share the link to the file so anyone can check it.
Vincent_Huss
May 6, 2024 4:28 PM UTC
Here’s a link to the file
the culprit is the item on the left named gradient2
Figma – 15 Apr 24
tank666
May 6, 2024 4:54 PM UTC
It looks like this is still a bug in the Plugin API. At the same time, everything is fine in the REST API.
I recommend changing the topic category to Bugs.
Vincent_Huss
May 7, 2024 2:12 AM UTC
ok done, thanks for looking into it
