Copying an image from the fill panel doesn't work anymore
Jazz_Ernest
I noticed recently when I try to copy an image from the Fill panel and paste it on a different shape/instance it no longer works.
I use this workflow daily and while there are workarounds it’s driving me crazy how much it slows me down doing my job.
Best answer by Bruno Landowski
@Jazz_Ernest I found a solution in another post. Actually it still works but in a different way. Instead of copy/paste from fill panel, select the thumbnail by clicking on the left of the image (where there is the order change icon). The element will turn blue, and you’ll be able to copy or paste the image by pressing Cmd + C/V.
Bruno Landowski
Same here 😪
  • 2482 replies
  • April 30, 2025
Thanks for reaching out. I'm checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
Jazz_Ernest
  • May 2, 2025
I just wanted to add I updated to version 125.4.7 and the issue still is still persisting
Tom Reem
  • Figmate
  • 55 replies
  • May 15, 2025
Hey everyone,
Thank you for letting us know, ​@Jazz_Ernest — I can confirm that our internal team is actively working on a fix. In the meantime, I wanted to align on a workaround for anyone else who may be experiencing this issue: If the fill isn't selected when the Fill panel is open, copying the image may not work. However, if you select the fill first, then copy, it should paste as expected.
Let me know if this helps. Thanks again for your patience.
Bruno Landowski
Jazz_Ernest
  • May 27, 2025
@Bruno Landowski thank you! This is super helpful
Tom Reem
  • Figmate
  • 55 replies
  • May 28, 2025
Awesome, thank you for sharing this here ​@Bruno Landowski — and glad to hear it’s helpful for you as well, ​@Jazz_Ernest! 🎯
I went ahead and tested this within my own account, and it’s working just as you described. Really appreciate you both surfacing this experience — feel free to reach out if anything else comes up. 🙏
