Bug: Figma fuzzy search not working on component library
Dylan_Faust
Our icon naming convention uses PascalCase with no spaces—names like UiMiscHeart. When I try to search for an icon from outside the icon library, keyword-based searches don’t work unless I enter the beginning of the component name exactly. For example, searching for “heart” won’t return UiMiscHeart, but “uimisch” will.
However, when I search within the icon library’s source file, partial matches work as expected. This issue only occurs when searching from other files.
Did fuzzy search used to work more reliably across files? I feel like it used to behave better.
  • 4827 replies
  • April 14, 2025
Hey ​@Dylan_Faust, thank you for flagging this!
This seems related to a bug our team is already working on. We’ll pass this onto the team while they continue to investigate the issue.
  • 4827 replies
  • April 17, 2025
Hi ​@Dylan_Faust, thanks for your patience!
Our team pushed a fix for this. Can you please refresh your tabs and let us know if you’re still running into issues?
