Variants cannot be rearrange
Danubius Designer
Hi Figma Team🔆
When re-ordering variants, I have encountered several suspicious issues:
  1. The drag & drop icon is not aligned with the variants.
  2. The list does not scroll up when dragging the item.
  3. When dropping, the selected variant is placed in a completely different position than where I released it.
  4. When dropping, the selected item turns into another variant, making the list completely untraceable.
Can you please fix this issue? Thanks a lot in advance.
Aster_Ng
  • 5 replies
  • April 17, 2025
I’m facing the same issue. Has anyone found a fix?
It’s a bit frustrating—the sorting is messy, and I can’t rearrange it.
  • Figmate
  • 2038 replies
  • April 17, 2025
Hi ​@Danubius Designer , thanks for reaching out about this.
I understand you're having trouble reordering component properties, particularly variant properties.
I've tested it on my end, and it seems to be working fine. Could you please check a few things for us?
  • Is this issue occurring only in a supported browser, in the desktop app, or in both?
  • Could you try a quick fix to see if there's any difference?
    • Close any Figma tabs you’re not using, then
      • For the browser: Force-quit your browser and open Figma in a new window.
      • For the desktop app: Force-quit the Figma Desktop app and restart it.
If the issue persists, could you please send us a video showing exactly what you're seeing? Please record your whole Figma screen. This will help us recreate the issue on our end to get a clear understanding. Then, we can figure out the right team to escalate to if further investigation is required.
Thanks for your help!
Danubius Designer
Hi Junko3,
Thank you for your reply. I followed your suggestions but, unfortunately, the problem remained the same. I made and attached a recording to help you recreating the issue. Hope it will help!
Thanks
Minh_Thanh_NGUYEN-PAGES
I'm having the same problem. When reordering variants, the window automatically scrolls and this feature is unusable.
Aster_Ng
  • 5 replies
  • April 21, 2025
Just an update — on my side, the variant is back to normal. The sort icon is now aligned with the variant, and when I drag and drop, it lands in the correct position.
  • Figmate
  • 2038 replies
  • April 22, 2025
Hi ​@Danubius Designer, Thanks for taking the time to perform the quick fix, and share the GIF.
I gave it a try on my side, but I wasn't able to reproduce the issue – it seems to be working as expected here.
To look into what might be going on with your file specifically, I've gone ahead and created a support ticket for you using the information you provided.
Our support team will be in touch to assist you with this matter. Please keep an eye on your inbox—you'll receive an email about the new ticket soon. It will be sent to the current email address we have on file for your account.
Aster_Ng
  • 5 replies
  • April 22, 2025
Hi ​@Junko3 , this issue occurs when there are more than 20 variants. Based on my previous experience, once the variant count exceeds 20, the sort icon becomes misaligned with the variant options.
However, my current Figma setup is working fine now, even with 20+ variants.
Doug2
  • April 22, 2025
I too am having this issue. The issue only occurs when I scroll down in the pallette. As you can see in the screenshot, I have scrolled to the bottom of the pallette and the move icon is misaligned.
It would be great if this pallette could be resized too in order to see all variant values.
I have 14 variants. The zip file contains a short video showing the issue. I had to zip it in order for your system to recognize the file.
This is occuring in the app on my mac.
In Chrome (Version 135.0.7049.96 (Official Build) (arm64)) it appears to be working correctly.
Update: I was reading through the thread again and saw that restarting the app might fix the issue and it did for me. For now the issue is no longer occurring.
The same variant is selected pre-scroll and the alignment of the icon is ok
