Sharing Labraries between Files
  • April 7, 2025
  • 8 views
Ammar_S_Mitoori
Hi,
Im a single designer, with no team, and I have few files of UI Kits, so to be able to use them and for the instances to get component updates do I need the Pro plan ? isn't there a way in the free plan ? Or just the copy and paste way ?
Kind Regards
  • Figmate
  • 1870 replies
  • April 8, 2025
Hi ​@Ammar_S_Mitoori, Thanks for reaching out about this.
If you want to use design assets from your UI Kits file across different files, you need to publish the UI Kits file as a library. And it's available on our paid plans, as you already know.
In the meantime, you can definitely still create a component within one file and then reuse it as an instance in that same file.
Here are some resources that explain this in more detail:
I hope this clarifies things a bit. Thanks again for reaching out.
