Outlines cannot be selected
SandC
Hi, I’m not sure if I’m doing anything wrong but I can’t seem to select most elements in the Show Outline mode. I have many layers and it’s bit frustrating to not be able to select things under the layers. Appreciate the help to know if I’m doing something wrong:
  • Figmate
  • 1992 replies
  • March 12, 2025
Hi ​@SandC , Thanks for reaching out.
I tested viewing outlines in Figma Design, and I was able to select objects as expected, including hidden and nested layers.
To cover the basics, could you please check a few things?
  1. Is this happening only in a supported browser, in the desktop app, or in both?
  2. Is this issue occurring in a specific file or in all files?
  3. Could you please try these basic troubleshooting steps to see if there's any difference?
    • Close any Figma tabs you’re not using.
      • For the browser: Force-quit and then open Figma in a new browser window.
      • For the desktop app: Force-quit the Figma Desktop app and restart it.
If the issue still persists, I recommend submitting a support request directly to our support team by following this guide: Submit a bug report. This way, we can take a closer look at the issue for you!
Thanks again for reaching out.
SandC
  • March 14, 2025
Hi, thanks for your reply, just to respond below:
    - It happens in both, I have components that are background under some elements which can be selected, but some elements above cannot be clicked on or selected
    - It seems to happen in my current file only as it has many layers and components as background. For e.g. in image below, I cannot select other elements above the component background:
        - I’ve tried but doesn’t fix the problem
