Reusable list components that scroll
  • February 18, 2025
  • 64 views
Loren Tracy
https://www.figma.com/design/E8eUt0dH0HYBRtaG6Io5QG/Reusable-List?node-id=0-1&t=AkRiLdc1kw0cdYZT-1
I’m having an issue with creating a reusable list component that can have various amounts of list items that scrolls correctly.
I created a list item component group with 15 list items, embedded that into a list item drop down. I was hoping to just hide list items in that drop down component instance but the issue I’m having is the container keeps the original height which leaves a large white space at the bottom of my scroll.
How can I create this without having to make a list item component variant for each number if list items I need and have it scroll correctly?
(This works but seems insane)
Best answer by Nate_G
@Loren Tracy With Figma there are probably a dozen other ways to address this. But I created an example file where I show one way you could set this up, using minimal components.
In my example I also have the Scroll list hug (with a max-height) the list items if there are fewer than 5 items but if there are more than 5 list items it will scroll.
Hope this helps!
Link to Prototype >
Link to Figma File >
Nate_G
  • 180 replies
  • February 18, 2025
Hope this helps!
Link to Prototype >
Loren Tracy
  • February 18, 2025
@Nate_G Dude, Thanks! That is exactly what I needed and now I understand my issue. I was trying to handle the scrolling on the dropdown component instead of the list component.
Many thanks!
