Variant Change On Drag - Only Smart Animate?
MGibson
I’m new to Figma and have been doing a ton of experimentation and testing to get a feel for it and I noticed something very peculiar when trying to create an infinite carousel.
I created 5 square frames in a line and was able to switch to them via “on drag > navigate to > push”. I was able to build a working infinite carousel this way. I then grouped those frames together as a component set, so now they are all variants, and still… it worked as intended.
But something I found interesting, was that if I created the variants first, WITHOUT the “on drag > change to > push” settings already established, it would not allow me to add those settings after the fact. The only option for changing would be “smart animate.”
Why is this?
Vishal_Ramawat
Seems like a Bug. Have same behavior
Even for the first way. After you convert them to component set, all options are greyed out.
MGibson
Yea, I thought it seemed odd. Even when changing between variants “on tap” or something other than “on drag” it at least gives the options for “instant” and “dissolve.” Unless you specify those settings beforehand.
Very strange. I made a simple infinite carousel relatively easy though, using the on drag setting with push.
Burak
  • August 23, 2024
As always, we have to spend hours to figure out why the hell we are being pushed to use Smart Animate and SOMETIMES Move in. And why are others animations are disabled…
Figma is terrible… terrible and still terrible. I just wanted to drag and change other variant by PUSH!!! damn!!!
