Riaz_Mohamed
Unable to view "Change Variable Mode" icon in layer panel
  • July 3, 2023
  • 30 replies
  • 8659 views
Hi ,
Unable to view the “Change Variable Mode” icon in the layer panel after the creation of variable
I am able to see the icon in Page level
I am using Figma Professional licence
Thanks in advance
Best answer by Zhorzhik_Grigoryan
In case of issues, please share the file to explore and assist you)
Zhorzhik_Grigoryan
Dear Reaz,
Make sure, you have set prior created variable to an element of that specific page. Once you assign any variable to an element, the icon will appear.
Riaz_Mohamed
Hey Thanks Zhorzhik,
Below is FYR
Zhorzhik_Grigoryan
Or you can select a button to see avalable variables, or you can change variable modes of all page from right top corner, marked with yellow in the screenshot.
Zhorzhik_Grigoryan
Hailin
Hello!
I had the same issue and I tried to set every element with a different mode then the icon shows up.
Popova
July 12, 2023
I have the same problem. I do not see the “Change Variable Mode” icon in the layer panel after the creation of variable. I have applied variables to a frame and set 2 mode, but I do not see an icon next to the layer panel.
July 23, 2023
This is because you may be using figma free version. I am also facing this same issue due to free version. I am also facing single mode in creation of variable. When i click on plus button to add second mode it require pay for 12$. We request from figma team please allow at-least two mode to free figma plan. 4 mode for paid plan.
July 23, 2023
Jonatan_Rosman1
July 28, 2023
Hi, I have the same issue. I have a professional license. I can see the icon on page level, and I can create several modes, but I can’t see it on the layer level. I have updated, restarted and reloaded Figma. Have anybody found a solution to this?
Does not work on layer level
Jonatan_Rosman1
July 28, 2023
Now it works, not sure what did the trick though. I tried publishing all new variables. I also tried to put mode on more collections (both primitives and tokens collection) etc, so maybe something of that did the trick, not sure.
