Stroke to scale with the object
Jairo
HI! just noticed that when i upscale an object with a stroke applied to it. the stroke maintains its width.
Is there a way for the stroke to scale with the object? (Just like in Illustrator)
Using Scale tool not an option, as it indeed scales up the width of the object, but when dealing idth icons, as soon as you swap an instance, the new instance reverts back to original width.
Thanks in advance
Vazgen
  • December 5, 2023
Hey @Jairo, had the same issue with the icons. Unfortunately Figma doesnโ€™t have the same functionality of scaling strokes similar to the illustrator.
But found a workaround by outlining the stroke of the initial icon. In these way, even if the instances are very small, the icon stroke will stay the same.
I hope this helps.
Pavlo3
  • October 9, 2024
Hi @Jairo, for fixing this issue you can convert stroked lines to stroke outline like in this tutorial
Figma Learn - Help Center
It converts line to shape and you can scale you SVG properly ๐Ÿ˜‰
Alexey Orlov
How to scale proportionally in Figma?
Scale layers while maintaining proportions โ€“ Figma Learn ...
Scale
  1. Activate the scale tool by pressing K , or by clicking in the toolbar and selecting Scale.
  2. Select an object.
  3. Scale the object by doing one of the following: Click and drag: Hover over the object's bounding box to make the cursor appear. Then, click-and-drag to resize.
