Van_Nguyen
June 29, 2023
SOLVED / Color switch: How to keep All Libraries open as default view?
After the updates, switching colors for me is a pain, as now it does not keep “All Libraries” as a default view anymore, every time I switch a color I have to select → choose a library or local or All libraries… It is such a pain. What is going on? Is there a way to keep All libraries open at all times?
I would assume it should remember the last selection, but no, it’s based on the color that was on it in the first place.
Tbh, such a change in UX should really be considered better, I wonder which genius thought it was a better idea to limit user’s view to only 1 library by default… 🫠
Celine_Solution
Hi everyone,
A fix has been deployed. Please refresh your tab.
If you are still having issues, please let us know by filling this form: here
Thank you!
Clare
I just encountered this colour issue too. Shouldn’t “All Libraries” be a default view?
Van_Nguyen
July 3, 2023
it’s driving me crazy, switching colors to try out design is now a massive pain @.@
dsp
@Figma_Support please revert this! It’s also driving me insane.
I often work in kind of a draft mode, not a 100% perfect product world with all styles set at all times.
Isaac_FOMO
July 5, 2023
Hello Community, hi @Van_Nguyen, I was thinking that he was a problem on my side, It’s very painful to work with many librairies. Please @Figma_Support Fix it.
Cory_Crouch1
August 2, 2023
Same for me. I would much prefer All Libraries as the default. Or a way to set it as the default. I’m having to do lots of extra clicks just to set colors.
Asfand
@Figma_Support Can please keep the old one I am also hating this.
Miranda_Bouck
August 15, 2023
Please fix this, it has been such a pain to support a major version upgrade of our design system with new atomic level elements with this setting being removed. Please make it possible for All Libraries to default or allow me to set it that way @Figma_Support
Hi all,
Thank you for your feedback, we hear you! 🙂 Our engineering team is working on a fix to default to all librairies. Thanks for your patience in the meantime.
Celine_Solution
Hi everyone,
Thank you!
Van_Nguyen
September 6, 2023
Massive thanks for fixing this issue so fast. I hope such a change in UX will be considered more carefully in the future (unless it was a bug). It is a small thing but it affects workflow dramatically. Thank you again!
