Mar 27, 2023 1:06 PM UTC
Remove figma website & project link in a prototype embed
Hi I have a prototype that I would like to embed to a website, my question is it possible to remove or disable the figma / project links at the top & bottom of the embed?
tank666
tank666Solution
Mar 27, 2023 1:19 PM UTC
tank666
tank666Solution
Oct 31, 2023 5:55 AM UTC
is doesnt work anymore is there any alternative available?
tank666
Oct 31, 2023 8:04 AM UTC
Sorry, I can’t confirm this. I just tested this on my end and everything works as expected.
Oct 31, 2023 11:03 PM UTC
Doesn’t work for me either, stopped working after a page refresh. It was working for me before.
tank666
Oct 31, 2023 11:47 PM UTC
Could you show the embed code?
Nov 1, 2023 12:06 AM UTC
interesting… it seems to be working again for now. I’d prefer not to share embed as it contains some sensitive information. I had tried both methods above but the only one that works for me is adding “%26hide-ui%3D1” to the end of the URL. Thanks for the response
Dec 29, 2023 5:56 PM UTC
May I ask what does %26hide-ui%3D1 means?
tank666
Dec 29, 2023 5:59 PM UTC
@Sabrina10,
Zack_Lewis
Jan 26, 2024 7:47 PM UTC
This is awesome. Thanks so much for sharing @tank666!
Apr 2, 2024 1:33 PM UTC
Without going through the major hassle of using a personal access token and fetching the nodes for each image, etc. and then displaying them accordingly on a site… is there any simple way to show a Figma image on a website and if you change that Figma image, it then changes on the website (without the canvas/UI elements…JUST the image itself).
None of the above work as I’ve tried all of them. The only way I could do it is with quite a bit of custom code because it seems they do store images on AWS for example: https://figma-alpha-api.s3.us-west-2.amazonaws.com/images/5bf61610-63d2-4ae6-8b75-2626d85504fc but I want to be able to ALTER that image and keep the same URL which doesn’t seem to be easily done unless you do something like this coupled with HTML that corresponds:
// Your Figma File ID
const fileId = ‘XXXXXXXXXXXXX’;
// Your Personal Access Token
const personalAccessToken = 'figd_X’XXXXXXXXXXXXXXXXXXX;
// An array of node IDs for the specific frames or objects you want to get the images for
const nodeIds = [‘65:3’, ‘75:14’]; // Add more node IDs as needed
// Fetch the image URLs from Figma for multiple nodes
async function fetchImagesFromFigma() {
const url = https://api.figma.com/v1/images/${fileId}?ids=${nodeIds.join(',')}&format=png;
try {
const response = await fetch(url, {
method: ‘GET’,
headers: {
‘X-Figma-Token’: personalAccessToken
if (!response.ok) {
  throw new Error(`Failed to fetch images from Figma (status ${response.status})`);
const data = await response.json();
// Assuming you want to embed the images in <img> tags with IDs corresponding to node IDs
nodeIds.forEach(nodeId => {
  if (data.images && data.images[nodeId]) {
    document.getElementById(nodeId).src = data.images[nodeId];
  } else {
    console.error(`Image not found for node ID ${nodeId} in response data:`, data);
} catch (error) {
console.error(‘Error fetching images from Figma:’, error);
// Call the function to fetch and display the images
fetchImagesFromFigma();
