Publishing icon library took so long
nguyen_dang
Hi Figma friends!
I’m new to Figma. I just learned how to duplicate and publish icon library so I can use them in my projects.
Unfortunately, it took so long, like forever, to publish. The issue happened to this particular library only. I know this one is large but the publishing progress never pass 10%, even after half a day!
My network speed:
I should wait 1-2 days for it to publish or can I do something to address the situation?
Any help is appreciated. Thanks!
Phil_Larsen
  • Active Member
  • 130 replies
  • May 29, 2021
Did you figure this out?
I know that if I have a larger library file it can take a while to upload. The same happens if it has a lot of pages.
You could pull the icons from the document that you’ll actually use to reduce the size of the file.
nguyen_dang
The issue still remains, but I guess it’s okay to pull icon directly from the other project. Thanks for the tip!
Phil_Larsen
  • Active Member
  • 130 replies
  • May 29, 2021
Yeah, I usually just have the icons I use in the document so it can publish quicker.
Boyan1
  • December 5, 2022
Same with me - Material Design Icons does not want to publish. I noticed there are links to missing library styles in the same file, so i wonder if that might be an issue. Or do we need to clean the cash and do some resetting?
Pacdev
  • January 15, 2023
Having the exact same problem here. Publishing usually works after a while on smaller icon libraries, but MD’s is just too large, I guess —I’m just gonna duplicate the main components to my project
Solo_Cube
  • 7 replies
  • January 16, 2023
The same issue is still here. Trying to publish the Material Design icons set with 2086 components and get the “Publishing failed:” error after 10+ minutes of waiting…
Matt_Willett
This is a painful process. The only solution is to publish batches of the icons at a time - I’m trying to publish material icons which has 6500+ icons, and manually checking around 1000 icons at a time to publish, this process alone manages to eat all the time the Figma saves in other areas. Maybe a button to ‘select first 500 components’ wouldn’t be a bad start
