Promise-based messaging between plugin and ui
  • January 12, 2023
  • 4 replies
  • 1185 views
rob-redbar
Does anyone know of a way to do promise-based messaging between the plugin and the UI? (@Gleb 🙂)
Using the globals:
parent.postMessage(...)figma.ui.onmessagefigma.ui.postMessage(...)window.onmessage can lead to spaghetti code… promises would be so much cleaner.
Really only the UI → Plugin direction would be fine, e.g.:
someCoolMessaging.post(type: 'get-some-data', payload: { id: 5 }).then(data => {
    console.log('got some data', data)
.catch((error) => {
  console.log('error getting data from plugin')
  • 4710 replies
  • January 13, 2023
rob-redbar
  • 6 replies
  • January 13, 2023
figma-messenger seems to be just a type-safe version of 1-way comms, but html<->script I/O seems to have a way to do async/promises. Will try it, thanks!
Michael_Yagudaev
I’ve created a library for it, and maybe I should publish it. It is built on top of Utilities — Create Figma Plugin with 3 basic primitives: req, res and subscribe.
I should probably publish it too.
This emit utility will help a lot. Any mechanism that abstracts iframe <=> iframe communication will help too.
In any case, what you are asking is
// ui.js
await Main.drawRect()
// main.js
function drawRect() {
  const rect = figma.createRect()
From what I’ve seen no other library currently supports this.
Jakub Hajduk
Hello,
in case someone is still looking for an solution to communicate UI and plugin code, I wrote figwire - lightweight, TypeScript-friendly library for seamless communication between Figma plugin and its UI.
 https://www.npmjs.com/package/figwire
