Preferred Values in Edit Instance Swap Property disappeared
  • January 16, 2023
  • 1636 views
Morgane_Lara
Hello 👋
A couple of days ago I noticed that the preferred values inside an edit instance swap property wasn’t visible anymore.
A colleague of mine looked on her side and she can see them perfectly on my file but I can’t. Although I can see the preferred values that have been set up previously when i click on the value field but can’t add any. And this is for all the components I previously set up with preferred values
If someone knows how to help 🙂
Thanks!
ps: I restarted Figma several times
Best answer by tank666
You probably need to re-enable the component properties beta feature.
Figma Help Center
tank666
  • 4863 replies
  • January 16, 2023
Figma Help Center
Morgane_Lara
It works 💃 thank you so much !
Remus_Baltariu
This is not working in a file that we build for a Thumbnail/Cover file component. Variants of a few components are not longer showing in the Preferred value dialog.
LE: the option from the screenshot is no longer available, supposedly is not in Beta anymore.
