Nested element cannot be resized
  • January 20, 2023
  • 6 replies
  • 2149 views
Adriano
I have a component that includes a list made with Autolayout.
I need some of those items to have different heights.
When I use the component in my design I cannot specify the size of the list items, they can only be Hug or Fill, and when I choose Fixed the size input field is greyed out.
If I choose Fill on the list items they will change their size based on the container, so I could resize them by adjusting the size of the parent. But that will make all of them the same height. I need them to be in different sizes.
How can I make each list item in a different size?
  • 4710 replies
  • January 20, 2023
You can’t modify the size of items inside a component instance. So a solution would be to not use a component instance here.
Adriano
  • 10 replies
  • January 20, 2023
I see.
It would be fantastic to be able to override the element size when inside another component.
I’m designing a table, and I have components for each Column. I have different Cell Components I can switch to change content. And sometimes the content of the cell is big enough that they become higher, so I will have to change other cells which might not have the same content so I can’t use Hug in there, I have to use an arbitrary height.
tank666
  • 4873 replies
  • January 20, 2023
So you’ve taken the wrong approach. Instead of a column component, you need a row component.
Adriano
  • 10 replies
  • January 22, 2023
I think the problem is that I have “an accordion inside an accordion”. So regardless of how the table is composed, I won’t be able to resize a component nested inside another.
I wish there was a way to assign an arbitrary size for elements inside a component.
Olivier15
  • 8 replies
  • May 10, 2024
This is still an issue… (Especially necessary for table components, either if you use row or column components)
Dustin_Hansen2
It is very odd. You can switch from Fixed to Hug or Fill. But you can’t modify the fixed size. It doesn’t make sense to me.
