jk2K
Marked(markdown parser and compiler) not work in figma sandbox
  • May 14, 2023
  • 6 replies
  • 788 views
my code
install marked
npm install marked @types/marked
// This plugin will open a window to prompt the user to enter a number, and
// it will then create that many rectangles on the screen.
// This file holds the main code for the plugins. It has access to the *document*.
// You can access browser APIs in the <script> tag inside "ui.html" which has a
// full browser environment (see documentation).
import { marked } from 'marked';
const html = marked.parse('# Marked in Node.js\n\nRendered by **marked**.');
console.log(html);
// This shows the HTML page in "ui.html".
figma.showUI(__html__);
// Calls to "parent.postMessage" from within the HTML page will trigger this
// callback. The callback will be passed the "pluginMessage" property of the
// posted message.
figma.ui.onmessage = msg => {
  // One way of distinguishing between different types of messages sent from
  // your HTML page is to use an object with a "type" property like this.
  if (msg.type === 'create-rectangles') {
    const nodes: SceneNode[] = [];
    for (let i = 0; i < msg.count; i++) {
      const rect = figma.createRectangle();
      rect.x = i * 150;
      rect.fills = [{type: 'SOLID', color: {r: 1, g: 0.5, b: 0}}];
      figma.currentPage.appendChild(rect);
      nodes.push(rect);
    figma.currentPage.selection = nodes;
    figma.viewport.scrollAndZoomIntoView(nodes);
  // Make sure to close the plugin when you're done. Otherwise the plugin will
  // keep running, which shows the cancel button at the bottom of the screen.
  figma.closePlugin();
got error
how to fix the error?
what is the reason for the error ?
Best answer by jk2K
fixed.
correct ✅
esbuild code.ts --bundle --target=es6 --outfile=code.js
wrong ❌
esbuild code.ts --bundle --outfile=code.js
refer to
https://esbuild.github.io/api/#target
esbuild default target is esnext
refer to esbuild - Content Types
Syntax transform Spread properties transformed when --target is es2018
Figma plugin backend (sandbox) only supports es6(es2015)
so we need change esbuild target to es6
Power Member
May 14, 2023
jk2K
jk2KAuthor
  "name": "test2",
  "version": "1.0.0",
  "description": "Your Figma Plugin",
  "main": "code.js",
  "scripts": {
    "build": "tsc -p tsconfig.json",
    "watch": "npm run build -- --watch"
  "author": "",
  "license": "",
  "devDependencies": {
    "@figma/plugin-typings": "*",
    "typescript": "*"
  "dependencies": {
    "@types/marked": "^4.3.0",
    "marked": "^5.0.2"
my tsconfig.json
  "compilerOptions": {
    "target": "es6",
    "lib": ["es6"],
    "strict": true,
    "typeRoots": [
      "./node_modules/@types",
      "./node_modules/@figma"
only tsc used
  "name": "test2",
  "id": "1235966160601492466",
  "api": "1.0.0",
  "main": "code.js",
  "capabilities": [],
  "enableProposedApi": false,
  "editorType": [
    "figma"
  "ui": "ui.html"
jk2K
jk2KAuthor
I want to use marked on the plugin backend, not the plugin ui
Power Member
May 14, 2023
The default TS compiler can’t bundle libraries into a single file unfortunately, so you can’t use it when you need to use any libraries/frameworks in your code. You’ll need to use Webpack, Esbuild, Rollup or other bundlers to do this.
jk2K
jk2KAuthor
change to use Esbuild
  "name": "test2",
  "version": "1.0.0",
  "main": "code.js",
  "scripts": {
    "build": "esbuild code.ts --bundle --outfile=code.js",
  "author": "",
  "license": "",
    "typescript": "*"
  "dependencies": {
    "esbuild": "0.17.19",
    "marked": "^5.0.2"
run npm run build
got error
jk2K
jk2KAuthorSolution
fixed.
correct ✅
wrong ❌
refer to
