Ankit5
Dec 11, 2023 6:09 AM UTC
Keyboard shortcut are overriden by Notion running on background
Hi folks
Whenever I try to import photos on Figma frame with the keyboard shorcut Cmd + Shift + K, Notions’s search windows open (Because it has same shortcut) The action takes place in Notion running in background instead active Figma window.
Can anybody help?
Gayani_S
Dec 11, 2023 4:00 PM UTC
Hey Ankit, the shortcut works on my end. Is this happening in the browser or the desktop app? Or both? Also could you share a screen recording with us, so I can share this internally and ask the team.
Ankit5
Ankit5Author
Dec 19, 2023 6:40 AM UTC
@Gayani_S ,
the shortcut Cmd + Shift + K is working fine when Notion is not running on the background.
Once I open Notion and switch back to Figma and press shortcut keys, it performs action on Notion.
I am using Desktop app.
Check this video
Power Member
Dec 19, 2023 7:08 AM UTC
If you switch to a different app (not Figma), does pressing Shift + Cmd + K activate a Notion shortcut?
Ankit5
Ankit5Author
Dec 19, 2023 7:19 AM UTC
Oh, yes it does
Power Member
Dec 19, 2023 7:52 AM UTC
In this case this is a Notion issue, I think there should be a setting for that in the app but I don’t know for sure.
Dec 20, 2023 1:55 AM UTC
Just had this issue. You can indeed fix it on Notion’s end.
In the notion app, go to Preferences > My settings. Then either disable “enable command search” or change the shortcut to something else.
Jan 18, 2024 9:56 AM UTC
Thanks ! It worked
May 23, 2024 8:27 AM UTC
in notion if you go to settings & members > my setting > you can disable the " Use command search" feature. You can also customise the shortcut to something else if you want to keep. I changed mine to cmd+shift+spacebar.
