How to make a vertex on each intersecting vector line?
  • February 19, 2021
  • 4 replies
  • 1385 views
Mr.Biscuit
This may be an embarrassing question to ask, but hey how do you actually make each intersection point a vertex without manually adding them using the pen tool?
I’ve tried union → flatten, but then it creates 4 vertices there(packed together) instead of 1 since a union turns paths into surface areas.
I need these vertices because then I can generate a dot on each of their spot using DotsOnVertices, without vertices I don’t know where to place my dots.
If there are any programmatic ideas that you could think of, that’d also be helpful.
  • February 19, 2021
In the early Figma years, it was as simple as pressing Cmd/Ctrl + E (Flatten the object). I don’t know why they removed this feature. 😦
Vladimir_Krstic
No plugin that solves this? I’m clicking here like a maniac. -.-
Vladimir_Krstic
@Mr.Biscuit Figured a workaround for this. Duplicate the object and then flatten them together. Edge intersections will get vertices. Still, it doesn’t work when edges are just touching. Still, better than nothing.
Skyoxima
  • January 23, 2025
This worked perfectly for my case, thank youu!
