Nov 19, 2024 5:30 PM UTC
How to edit text in a component from MD3 library
Hello, I’m new to Figma in terms of creating designs and for the life of me I cannot find out how to edit a text label in a component I am using from Material Design 3 assets. See below screenshot. How do you customise text? I’m sure it’s something easy once I know how or I don’t have permission. Apologies if this covered else where. Google and searching didn’t return a simple answer. Thanks.
Craig_C1Author
Nov 19, 2024 5:42 PM UTC
Material 3 Design^ to correct myself.
Johnson_Ryan
Nov 19, 2024 9:16 PM UTC
Select Menu list item 1 layer in the layers panel. This should bring up props at the top of the right panel.
EDIT: props used to be at top right, now they seem to arrange differently in UI3.
Craig_C1Author
Nov 20, 2024 4:33 PM UTC
Hi, nope still not seeing props top right…
Craig_C1Author
Nov 20, 2024 4:36 PM UTC
I have solved this as I downloaded the desktop app. It seems theres something needed in the web browser version on Safari that requires fonts to be installed as fonts were not found.
Craig_C1Author
In fact I can’t seem to type free text! If I use the text tool, it creates the text area but I can’t type anything!
Johnson_Ryan
Nov 21, 2024 5:17 PM UTC
Is the “Label text” prop in the right column not sufficient?
(Note: I didn’t realize you’re still using UI2, which requires you to look for the section with “Menu list item” at the top.)
