How to delete a variant property
  • May 31, 2022
  • 14 replies
  • 20990 views
joshmillgate
I simply want to delete the property “Label Size” on all my variants. I could do this by renaming the layers and removing “Label Size=Sm” but I have hundreds of variants and that would take forever… I can’t right click on the property anywhere.
CleanShot 2022-05-31 at 16.47.11
tank666
  • May 31, 2022
First select the Component Set and then:
joshmillgate
Ah! Have to select the set, thanks!!
Alec2
  • July 21, 2022
Hi ! the solution don’t work for me : I select the the component set (“edit_info_layer”) which is composed of two variants with a single property (“SCOPE”). In the Properties parameters panel, no option will pop on a right-click. When hovering the property name, the edition icon is display and it only allows to rename or target the variant with each value.
Capture d’écran 2022-07-21 à 15.33.44
Any clue will be welcome 🙏
Thanx,
Alec
tank666
  • July 21, 2022
What do you want to do?
Alec2
  • July 21, 2022
Delete the property " SCOPE "
tank666
  • July 21, 2022
It is not possible to create Variants in a Component Set without properties, or delete a single property. If you don’t need properties, then don’t combine components as variants. And if already combined, then:
Alec2
  • July 25, 2022
  1. Select all variants and drag outside the purple border.
Works great and simple as " Bonjour ". Thank you so much 🙏
Rob28
  • October 4, 2022
This is great, but is there a way to do this without losing the component description?
tank666
  • October 4, 2022
Which layer (object) has a description added to? To a Component Set or Variant within a Component Set?
If to Variant, then the description should remain.
Rob28
  • October 4, 2022
I understand. Unfortunately, the description is added to the component set.
To give you more context, I’m talking about the official Material Design Icons library. I was trying to extract one style but keep the description tags from the component set for better search results.
Thank you for your time!
tank666
  • October 4, 2022
I can only suggest that you write a script (or find a plugin in the Figma Community with such functionality) that will take the description from the Component Set and apply it to the Variants within it.
Rob28
  • October 4, 2022
I’ll keep digging. Thanks again!
CJ_Josephs
  • October 13, 2022
Exactly how I found this thread. I have removed all variants and have “rounded” left and would like to remove “rounded” and leave the icon asset the way it is.
MiloW
  • Active Member
  • October 15, 2024
Well, I have no variants, just one element in the component and I click - and nothing happens, it just resets my property to Default… OMFG
