How to add google maps embed?
  • January 26, 2023
  • 4 replies
  • 22943 views
Kian_javadi
Hello,
Ive been trying to add an interactive google map to a Figma prototype. When I’ve searched online it seems as though there has been a google maps embed plugin however, when I’m searching for this in the plugins and widgets section it does not appear. Im aware that there are plugins like mapsicle that offer static map images, however I’m looking for a dynamic map that can cover larger areas and change on zoom. Can you advise whether this is possible and if so how it can be done?
Regards,
Kian
Best answer by Armin_sarkhosh_afshar
Unfortunately, Figma does not currently support embedding dynamic Google Maps directly into prototypes. However, there are a few workarounds you can try:
  1. Use a screenshot or image of the map: You can take a screenshot or export a static image of the Google Map and import it as an image into your Figma prototype. This will not allow for the map to be interactive or change on zoom, but it will allow you to show a visual representation of the map in your prototype.
  2. Use a third-party plugin: As you mentioned, there are plugins like Mapsicle that offer static map images. While they may not allow for a fully interactive map, they may offer more functionality than simply using a screenshot or image.
  3. Use an iframe: You can embed a Google Map into your Figma prototype using an iframe. To do this, you will need to generate an iframe code from Google Maps and insert it into your Figma prototype using the Embed tool. Keep in mind that this method may not work smoothly in all browsers and devices, and may not offer the same level of interactivity as a fully integrated map.
Overall, while it is not currently possible to directly embed a dynamic Google Map into a Figma prototype, there are workarounds that can allow you to display a visual representation of the map in your design.
tank666
  • January 26, 2023
You can’t embed iframes in Figma prototypes. All you can do is simulate a map by creating an interactive component.
Fred_Erick
  • January 26, 2023
You can try the “Frames” plugin or a HTML plugin and add the iframe code.
manishrsilwal
I think you should try the plugin Mapsicle for this.
