Glide (Hover) to reveal?
Ivan1905
Hi is this possibel to do on Figma? I am aware it is coding, but is their a simple way to do so on figma.
Best answer by Nate_G
@Ivan1905 Not as fancy as the code, but you can use a hover + smart animation effect to get somewhat close to that.
https://www.figma.com/proto/LxISnpWOJDv0HB0vAfQGC6/Hover-to-Review-Code?page-id=0%3A1&node-id=6-26&viewport=764%2C467%2C0.64&t=yLeAckuoCzbGhvW7-1&scaling=min-zoom&content-scaling=fixed&starting-point-node-id=6%3A26&hotspot-hints=0
View the Figma file >
Nate_G
  • 180 replies
  • March 18, 2025
Ivan1905
  • March 19, 2025
Hey Nate, this is amazing, thanks so much, although for my File I am using a image instead of numbers, and it seems like it zooms into the the image from the top Left, and no centrally, do you know how to fix this? Here is the file.
https://www.figma.com/design/mrSymNNo62DFFfdx9CA4Y8/Stamp-(Glide-to-Hover)?node-id=0-1&p=f&t=evSSQmxxqPoRYxnS-0
Nate_G
  • 180 replies
  • March 19, 2025
@Ivan1905 if you want it to scale from the center, add auto-layout to both variants in that component (see below).
