Farzona
Jan 18, 2023 3:10 PM UTC
Changes published in library are not updating component instances in other files that use the library
Hi there,
We have a team library with components, and other project files using instances of these components. When publishing changes to the master component in the source file (library) we stopped receiving the “Review and accept library updates” notification in other project files and obviously component instances were not updating.
Yesterday (17.01.2023), this notification was appearing but the changes were still not applied in component instances in other files.
This is an important issue, as all our work relies on the libraries working properly. Urgent help would be appreciated.
Thanks.
UPDATE: I tried solution #3 from this thread and it is still not working.
Manuela_Mesterhazy
Aug 15, 2023 4:11 PM UTC
UPDATE ⚠️
I spoke to Figma and they figured out what happend on my end, maybe it helps some of you.
If you have variants applied to a library component, all labels must have a unique name. Figma displays a conflict error if variants have the same value, but if you have a library component and the setting labels are called the same, this conflict error is not displayed. The system recognizes it as a conflict and therefore it won’t update the component until it is fixed, so it will never show up in your updates, even if you think you have published it.
Make sure all labels in your settings are unique.
Here was my mistake to give you an example (see image attached). We have two secondary buttons in the toolbar library component. The value can be off/on, so no conflict there, but because there are two items called secondary button, the system cannot map it correctly and the “conflict” was never communicated to me, so I did not know this was the reason why my component would not update and be published.
Padmon
Mar 13, 2023 11:58 AM UTC
I have the same exact issue. I’ve update the main component but my instance component in other files does not change and also the properties in the component is the old version
DeAnna
Mar 21, 2023 4:19 PM UTC
I am also seeing this issue. The layers within in the main component are changed but it doesn’t show in the children not in the origin file.
Mar 21, 2023 4:48 PM UTC
Hey All,
To try to repair the connection with the components and the library can you please try the following:
  1. Open the file with the instance with the issue and select the instance
  2. In the top left click the main menu and click ‘Quick Actions’
  3. Search the command “repair component connections” and click this to run this command
  4. Once complete refresh the page, then try publishing a new change and check if the update shows in the file
Farzona
FarzonaAuthor
May 2, 2023 11:39 AM UTC
I have tried this back then too, it didn’t work. However, Figma released an update to fix the issue I was talking about, and apparently not only me. It is working fine now.
Vincent_Teng
Jun 23, 2023 7:22 PM UTC
This issue came back for me around 2 days ago. Tried the steps listed above and it didn’t work. Any suggestions? Wait for an update?
Magda_Reyman
Jul 20, 2023 12:36 PM UTC
I have the same issue but the notification about the update does not show.
Jul 25, 2023 4:58 AM UTC
Hey, we have also had the same issue and what helped was for everyone apart from one person to get out of the file, multiple people working on the same components and file was causing the problem. Then Figma refreshed itself and started registering the component updates in the library.
Omar_Chelbat
Jul 25, 2023 7:05 AM UTC
We are also experiencing this same issue.
Changes are being published, but none of the components are being updated. If I drag the updated component from the asset panel then it’s indeed the latest version, but we have so many child components that this isn’t a feasible way of doing it every time a change happens.
We’ve been dealing with this for many days now.
Now it suddenly started working. It’s very come-and-go and has caused about 3 hours of delay in work today. Please fix this ASAP as it’s costing a lot of man-hours and delays.
Manuela_Mesterhazy
Jul 25, 2023 3:03 PM UTC
I have the same issue. I changed an item in a library component and the changes do not show up in an already existing file. I tried all the solutions mentioned here but it does nothing. Even if I change the component, it doesn’t show up as a possibility to update the other file either. Please fix this!
And randomly other components show up that apparently were updated, yet they were not changed, so they shouldn’t even appear in the “Publish New Version” area. WEIRD
Jul 26, 2023 2:26 AM UTC
Same. This is super frustrating. I’ve spent the last month working on a brand-new design system for my company, everything worked fine last week, and now one of the most asked-for components is not updating.
I tried the “Repair Component Connections” trick, but it didn’t work.
