Change a library component intance based on variable
Jimmy_Moutzouris
In my main file im pulling a external style sheet which controls light/dark mode which all works fine. Im also pulling in graphics (logos, illustrations etc) from a different library. This library has component with 2 instances of the same illustration (light and dark).
What I want to do is from my main file toggle a variable which swaps all the graphic instances? Is this possible?
Best answer by Avokadomos
On the instance, click on assign variable (only visible when you hover the section).
Avokadomos
You can apply a text variable to the instance’s variant property, and then set the text variable to any variant name.
Jimmy_Moutzouris
How do you apply a variable to an instance variant property?
Avokadomos
Jimmy_Moutzouris
Thank you Champ
Avokadomos
No worries! Remember to mark this topic as resolved.
Jimmy_Moutzouris
Before I close this, any way to apply the instant variant property to an instance that is within another component? Seems like not possible?
Avokadomos
That is correct. Variables can’t be used in nested components, at least yet.
