Vignesh8
Sep 20, 2024 4:33 AM UTC
Cannot redeclare block-scoped variable 'console'.
Hello everyone,
I’m developing a Figma plugin using the create-figma-plugin toolkit by Yuanqing. I’m encountering two problem
  1. Whenever I modify the UI of my plugin—such as changing fonts, colors, or other styles—the changes do not reflect when I run the plugin in Figma.I’ve tried rebuilding the plugin after making changes, but the UI remains the same.
  2. Error When Running npm run watch When I execute npm run watch, I receive the following error message:
node_modules/typescript/lib/lib.dom.d.ts:16669:13 - error TS2451: Cannot redeclare block-scoped variable ‘console’.
16669 declare var console: Console;
node_modules/@figma/plugin-typings/index.d.ts:11:9
11 const console: Console
‘console’ was also declared here.
Found 2 errors. Watching for file changes.
   This error seems to be related to TypeScript typings conflicting with Figma's plugin typings.
  Additionally, when I install `@create-figma-plugin/ui` or `@create-figma-plugin/utilities` separately, I encounter different errors.
