Apolline
Dec 18, 2023 12:18 PM UTC
Can't remove min and max height when the component is nested
Hello,
I’m having issues with the min/max height and width. When my component is nested, I can’t remove its min and max height, so I have to detach the parent instance everytime
Standalone instance
Nested instance
After I detached the parent component instance
Dec 19, 2023 2:10 PM UTC
Hey Apolline,
Sorry to hear you are having issues! It’s a bit complicated to replicate the issue without a copy of your file. Would you mind sharing a copy of your file here so the community can try to replicate it? Please also share a quick video recording, or screenshots of each selected layer in each example (this will help us to see the layers panel for each of the three actions).
If you are hesitant to share it publicly, please reach out directly to the support team here: https://help.figma.com/hc/en-us/requests/new Thank you!
TiffaniF
Mar 27, 2025 2:53 PM UTC
Was it solved? I have this issue all the time.
Dustin_Hansen2
Apr 4, 2025 6:29 PM UTC
​@Celine_D does this help show the issue?
Example 1:
Example 2:
