paddy_duke_valla
Oct 4, 2023 3:44 PM UTC
Can't publish library and many components are failing to load
I’ve had a strange issue with our team library for the last couple of days. I’m getting no help from the error messages, and I can’t find any fixes in other topics.
I can’t publish any changes to the library at all. There don’t appear to be any errors with the components. The publish pop-up is also showing 60 changes when I have only made a couple changes to existing components. Hitting publish with any of the components selected shows a red error notification: “Unable to publish X changes to the Team Library”.
Meanwhile, other files using the library are showing that there are some updates, but they are for other components that haven’t been changed, and the timestamps for the changes don’t make any sense. They are showing lots of different changes at various times in the last 2 days, while I have been unable to publish. The list of components with updates doesn’t include any of the ones I’ve changed recently.
Accepting these updates doesn’t apply any changes to any of the components anyway. The “Component update available” notifcation reappears if I reload the tab, with the exact same list of (unexpected) changes.
On top of all this, I’m unable to use a lot of the components from the last publish as they are failing to load properly. Selecting them in the assets panel loads the preview window, but shows a yellow notice that the component could not be loaded. Dragging the component out of the assets panel does nothing. This is the case for about half of the components. The others work fine (albeit they can’t be updated).
Has anyone else encountered anything like this before? The lack of feedback from the system about why it’s not working is driving me nuts.
I’m not missing any fonts used in the components, which was a fix in a similar-ish thread from last year.
Oct 18, 2023 9:22 PM UTC
also having issues, I keep having to close and re open Figma, no errors just won’t give me the notification
also for some reason random things keep happening, right now my buttons, despite not touching them, has decided to rest the text on every single BUTTON component… which has caused a lot of issues you can imagine
Oct 30, 2023 9:53 AM UTC
Hi @paddy_duke_valla, thank for these details. I checked in our backend that our technical support team is working on your issue, and wait for your reply. Please check your inbox, thank you!
ArantjaR
Jan 9, 2024 4:33 PM UTC
I had this issue as well, I found out that the problem was the following. I accidentally made a component loop by adding a “child” component within the parent that was also used in the child component. After removing that it worked again.
Kara_Hockley
Jan 24, 2024 9:19 AM UTC
I am still having this issue and cannot publish, can someone please help?
Aarjav_Pandya2
Jan 24, 2024 3:08 PM UTC
I am facing the same issue, I have the master/parent and child components in the same file, and I can see the child component, but the file isn’t loading/displaying the master component.
Aarjav_Pandya2
Jan 24, 2024 5:42 PM UTC
Is this still being worked on? Facing issues and not being able to proceed with work.
Jan 25, 2024 9:38 AM UTC
Hey @Aarjav_Pandya2 , the issue has been solved. Please try to refresh your browser / desktop app. Still, if you are still having issues, please reach out directly to the support team with a copy of your file, so we can investigate further here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as an Editor so they can take a closer look.
Aug 5, 2024 3:57 PM UTC
Hi there
I have had this issue for the past 5 days now, and 18 components cannot be published to the team library.
I have tried everything, refreshing, restarting the app, web version… there are no errors on the components, and the support via the link you shared has not got back to me.
Thank you
Aug 7, 2024 12:47 PM UTC
Hey Francois, welcome to the community! Thanks for reaching out directly to the support team. I see in the backend that the support has escalated your case to our engineering team for further investigation as the tool isn’t behaving the way we’d expect it to. Please continue the conversation via email to get the update.
Thank you for your patience while our team is investigating it!
Liz_Phung
Oct 11, 2024 10:45 PM UTC
Hi there, I’m having the same exact problems. Has this been fixed for anyone else?
