Elba1
Dec 1, 2022 7:23 PM UTC
Can't create text styles
When I create a text and then click the Style icon on the right menu, then click on the Plus icon on the Text styles button nothing happens. Is there a chance I’m missing something? Help!
Sanne1
Jan 6, 2023 3:01 PM UTC
Have the same issue… Anyone knows how to fix this?
Mango_90
Feb 13, 2023 8:37 AM UTC
Not sure if you came to a solution on this, but I just hit the same wall, and realised in my case it was because I had a mix of style attributes in a line of text.
For example in my case, I had two words in the paragraph with an underline on them.
Removing the underline let me add the text style as usual.
So check the text you’re trying to create a new style for, you may have part of it styled differently.
The confusing part is that when you click the + to create the style, nothing happens at all.
Really there should be a notification somewhere telling you. “You can’t create a new style because this element has mixed styles in” or similar.
Jun 26, 2023 4:59 PM UTC
This worked for me too.
Jan 17, 2024 8:37 AM UTC
Same issue here, did anyone find the solution?
Gayani_S
Jan 17, 2024 5:43 PM UTC
Hey Lena, would you mind send us a screen recording on what you’re seeing on your end? It does work on my end.
Feb 2, 2024 1:26 AM UTC
Hi! I was having the same issue and I would like to make a suggestion. When you select the text that you want to make a style for, make sure that you have a number value selected for the size of the text. When I was struggling with this same problem, I found that in the text size box it read “Mixed”. Once I added the correct text size that I need it allowed me to add it as a style. I hope this helped.
LeddaRa
Sep 2, 2024 12:57 PM UTC
Hi all. Same problem. Text line not mixed, simple text, nothing special, but cannot create style 😦
