[BUG] Issues Paragraph spacing
  • November 22, 2023
  • 11 replies
  • 986 views
Alejandro_Larramendi
I am running into BUG when applying paragraph spacing to a type style. For some reason it’s not picking up the value that was set in the style. Only when I break the link to the style it picks up the proper Paragraph Spacing values that was set in the style.
I have try deleting and re-creating the type style but the problem it’s still happens.
Also seeing it happing with any other document that was Type Styles.
Is there a way to fix this issue?
Best answer by Ryan_52
Thank you everyone for the reports. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
Ryan_52
  • Technical Quality Specialist
  • November 22, 2023
Hi @Alejandro_Larramendi I’ve tested a text style with paragraph spacing on my end here but was unable to reproduce an issue when setting the text style to a text node.
If the text style in a library? If so can you try making a small change to the text style ( such as adding or modifying slightly the description) then publish and accept the updates. You can then revert your changes and re-publish again to see if that helps.
If you are still seeing an issue would you please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a short video detailing the issue you are seeing, include the links to all effected files and libraries, and share it with support-share@figma.com so they can take a closer look.
jpsear
  • November 23, 2023
I can confirm that I’m also seeing this bug. This is not a library publishing issue for me.
I have recorded a video of the issue, but apparently “new users can’t upload attachments”, so unfortunately I can’t post it 🤦‍♂️
jpsear
  • November 23, 2023
I’ve uploaded the video here, if you are happy to download it: https://file.io/Z3d0cA4bCdy5
  • November 26, 2023
Hello ! Same issue for me…
@Ryan_52
Here is a video of the issue.
Looks like it’s a BUB.
I see it happening on all my Figma files and have check with other people and they are having the have issue.
Paragraph Spacing not working with styles. Only after breaking the link it show the proper values for Paragraph Spacing.
Is there any way to fix this.
  • November 27, 2023
Video on the same issue
  • November 27, 2023
Can confirm, I have the same issue.
Ryan_52
  • November 28, 2023
Mirror
  • November 28, 2023
There is no problem with the Figma paragraph function, and it is also mentioned in the update record. I think you misunderstood paragraph spacing.
I think the question should be: “Changes between single-line spacing and multi-line spacing.”
What we need is to set the height of multi-line text.
