Backwards Autolayout and issues with prototypes
Elizabeth9
Has anyone experienced a weird bug where the autolayout align commands appear backwards to the expected result? I.e when I try to left align an autolayout it right aligns it instead. Also having issues with prototype previews within the same file. Wondering if it is a corrupt file or if others are having similar issues.
Best answer by David
@Elizabeth9 are you sure that the Rotation value is set to 0? It’s easy to recreate your scenario when the auto layout has a mirrored rotation set to it? You can still place objects in with the correct orientation, even when a parent is rotated.
Check my demo image here: https://uploadpie.com/KH2uVE
tank666
  • 4873 replies
  • July 24, 2023
Elizabeth9
  • July 24, 2023
They are not. It happens even when creating a net-new autolayout within this file.
tank666
  • 4873 replies
  • July 24, 2023
Could you share a link to this file?
Elizabeth9
  • July 24, 2023
Unfortunately it is for work and the file contains sensitive info that can’t be shared.
Josh
  • Former Community Manager
  • 1019 replies
  • July 24, 2023
Hey @Elizabeth9 are you able to reproduce this in a separate file by chance?
David
  • 9 replies
  • July 24, 2023
Elizabeth9
  • July 25, 2023
You are correct. This was causing the issue with the prototype preview as well. Thank you!
Josh
  • 1019 replies
  • July 25, 2023
Thanks @David for jumping in to help! @Elizabeth9 glad this was an easy fix for you! 🙂
jasha.aitchison
I have the same issue but none of the parents are rotated 🤨
It seems to happen randomly and only in the past few weeks.
Nellya
  • 664 replies
  • October 4, 2024
Probably it’s not rotated, but flipped
jasha.aitchison
It happens to new autolayouts I create and I cant imagine I am unknowingly flipping them all the time all of a sudden. Any idea how that might be happening?
