Asset Search is Completely Broken AGAIN
  • October 25, 2024
  • 5 replies
  • 107 views
Pete4
It just doesn’t return results. Generally, Figma been running sooooo slow. Constantly needing to reload pages/files each time you focus on the file… Then there are the conectivity issues (failing to save to cloud)… What a mess.
CleanShot 2024-10-25 at 12.41.59
  • 2317 replies
  • October 25, 2024
Hi there,
thanks for reaching out. It looks strange.
Could you try the troubleshooting below?
  • Close any Figma tabs you’re not using
  • Browser : Force-quit and open Figma in a new browser window.
  • Desktop App: Force-quit the Figma Desktop app and restart it. If the issue persists, try clearing the cache.
If the issue still continues, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link:
Figma Learn - Help Center
Thanks for your patience.
Toku
Pete4
  • October 25, 2024
Yes, tried all the usual tricks. Cleared App Cache, Uninstalled, reinstalled, restarted laptop… No joy.
Pete4
  • October 25, 2024
Ok I have discovered the problem is only in Libary Files, hope that helps.
Matthew_Schwartz
I’m experiencing the same issue with the search (and other issues noted which aren’t related, but are frustrating). When typing the name of an asset I know exists, it continually has the spinning circle and never loads any results. It doesn’t matter if I change which libraries I’m searching in.
I discovered something interesting which seems to have fixed the search (at least temporarily and at least for the project and files I was working with at the time I had the search issue).
Here’s the workaround / way I fixed mine:
I went to the project file which contains the assets I wanted to find, and then I made sure to publish all changes (note: the published changes had nothing to do with the assets I was searching for from the other file). When I went back to my current project file and searched, the assets immediately were found as expected.
I think there’s a bug in the library code which deals with publishing and updates. If a library has changes which aren’t published, regardless of whether they are related to the asset being searched, it seems to break the search from other projects / files. Hopefully this helps
I just sent this info into the Figma support to create a ticket. Hopefully it will help them fix the issue globally.
Kurt Schmal
I have the same issue with library files. Very frustrating.
