Using one-third or two-third in autolayout with fill container
Julian_Janssen
Is it possible to use fill-container and assign one element to one-third of space and the other two-thirds of space?
I need the component to be resizable.
Best answer by Brian_Saunders
You can use a regular frame with a 3-column layout grid to accomplish this one I think. Line up the child frames/objects with the column layout lines and set their constraints to Left + Right and they will follow the grid as it resizes. Set the frame with the grid on it to fill its parent auto layout container. Is this what you’re after? Sloppy GIF included. (edited to add layers panel screenshot)
thirds-example
CleanShot 2021-07-18 at 10.31.17@2x
Brian_Saunders
thirds-example
  • August 17, 2021
